Tempinou
May 26, 2015Aspirant
Raid 5, panne du NAS NV+, racheter le même ?
Bonjour, j'ai eu récemment un problème matériel sur mon NV+, l'alimentation a lâchée. J'en ai racheté une 100€ (pas donné) et tout est reparti. Cependant je me pose la question maintenant, ET SI ma...
RX
May 26, 2015Luminary
You will need to consider the compatibility of the disks and the NAS platform (x86, ARM or Sparc). You cannot just simply insert your existing disks to another NAS because it might just wipe out the data. However, if you will insert your existing disks to another NV+ NAS model then its just alright as long as you will insert the disks accordingly to their respective from which they were pulled-out.
Do you have a backup of all the data stored in your NAS?
Did you receive any e-mail notification that a disk/s has failed?
Is your NAS still detected on RAIDar?
What does it show on the LCD display of your NAS?
Regarding the difference of XRAID and Flex-RAID, kindly access this link: http://www.netgear.com/images/pdf/WP_XR ... 2May14.pdf
- Thanks to Google Translate. I am open to corrections :)
Améliorez vos compétences avec la Netgear Academy - Formez-vous, certifiez-vous et restez à la pointe de la technologie Netgear !
Rejoignez-nous!
