GiuSa58
Sep 09, 2019Aspirant
Apertura porte
Sto cercando di aprire la porta 5000 sul mio router D6400, eseguo la procedura, nella pagina del router la smarca regolarmente sull'indirizzo del mio PC, ma, se vado a verificare con diverse tools, l...
GiuSa58
Sep 12, 2019Aspirant
I need to connect an NVR to Dropbox
michaelkenward
Sep 12, 2019Guru - Experienced User
With luck, someone will know what an NVR is.
Network Video Recorder? And the make is?
- GiuSa58Sep 12, 2019Aspirant
Yes, video surveillance kit
- michaelkenwardSep 12, 2019Guru - Experienced User
Made by?
I assume that you got instructions from the maker as to what you need to do.
Try searching this community for the make. There's a chance that someone has already grappled with the issue.
It is very easy to assume that opening a port is the answer. In reality, it may be something else. That's why asking what you really want to achieve can be more useful.
