Vandergraff
Apr 06, 2021Apprentice
Netgear-Guest Open and Disabling Firmware Updates
As many have reported I often see a Netgear-Guest Open WiFi Network even when Guest Networks are disabled. I trraced the issue to one of my 3 satelittes - an RBS50Y. Netgear lists two firmwar...
Vandergraff
Apr 07, 2021Apprentice
schumaku wrote:I remember Vandergraff "open" guest network posts very well.
Suspect much more a sync or update problem from the primary router where the config happens to the various satellite models supported somehow.
This still happens on "modern" WiFi 6 Orbis, sometimes in wireless backhaul, sometimes in wired backhaul configuration.
The thing is it is quite repeatable.
When the RBS50Y runs 2.6.2.104 the Netgear-Guest Open WiFi Network is there when the RBS50Y runs 2.3.5.32 its gone.
Thanks
CrimpOn
Apr 07, 2021Guru - Experienced User
Can you humor me with an experiment? Enable guest WiFi and report whether there are now two guest WiFi networks, or only one?
Since the main problem is a desire to not have an "open" WiFi system, I would be tempted to enable a Guest network with a totally impossible to crack password, such as "BetYouWillNeverGuessMoreThan4OrLessThan250OfThesePasswordLetters!"
That only works, of course, if enabling your own "guest" WiFi network makes Netgear-Guest disappear.
Also still amazed that the RBS50Y updates firmware without any action on the user's part.
- VandergraffApr 07, 2021Apprentice
CrimpOn wrote:
Vandergraff wrote:
The thing is it is quite repeatable.When the RBS50Y runs 2.6.2.104 the Netgear-Guest Open WiFi Network is there when the RBS50Y runs 2.3.5.32 its gone.
With 2.3.5.32 and a secure Guest Network enabled Netgear-Guest Open WiFi Network isn't there (but it wasn't anyway without the Guest Network enabled).
Last week with 2.6.2.104 and a secure Guest Network enabled Netgear-Guest Open WiFi Network was there.
If I have time in next few days I will try 2.6.2.104 again with a secure Guest Network enabled
- Retired_MemberMay 02, 2021Have the same issue. After FW Update Orbi Shows Netgear-Guest. Reset Orbi or on/off do not fix the problem. Restart complete system also do not fix issue. When I activate real guest network Netgear-Guest disappears. Is their a real solution for this issue?
I can’t believe ist that their always issues when updating Orbi.
For this amount of money I though I get some better stuff. The last time I buying something from netgear. Their are so much trouble always with Orbi. This waste my time and money
