cldlhd
Jul 20, 2020Aspirant
Can't login to cm1150v
I just replaced my Comcast rented modem with a cm1150v 2 days ago. I'll get 360mbps down which is about 100 better then the old Arris but it will go down to 100mbps or lower pretty regularly until I r...
Jul 20, 2020Guru - Experienced User
Try using a different browser or pc. Its usually a google setting that has an option to click though.
And then get a screen snip of the cable connections page and logs. That can help us check the connection.
If you have any splitters, attenuators, or amplifiers in line, remove them. check the coax line for any damage, kinks, poor connectors or corrosion. If possible, move it to where the coax enters the home and try it there.
cldlhd
I'll give it a shot. I only have one coaxial cable coming into the house so it has to go to a splitter first because it also supplies my cable TV. It appears the slower speed is only in the one bedroom so I imagine that's down to the Wi-Fi. That's a bit surprising because it's a really good router. I'll try logging in on another browser on my phone instead of the laptop, thanks
- plemansJul 20, 2020Guru - Experienced User
If its only over wifi, then its a router issue. The CM1150V doesn't have an integrated router. its a modem only.
- cldlhdJul 20, 2020Aspirant
I know. I realised it was only slow in the one room after I posted. I still can't login to the modem to see my logs though. Tried different browsers
what error is it giving you?
What address are you using? try 192.168.100.1
have you tried a different pc/device?
