cldlhd
Jul 20, 2020Aspirant
Can't login to cm1150v
I just replaced my Comcast rented modem with a cm1150v 2 days ago. I'll get 360mbps down which is about 100 better then the old Arris but it will go down to 100mbps or lower pretty regularly until I r...
cldlhd
I'll give it a shot. I only have one coaxial cable coming into the house so it has to go to a splitter first because it also supplies my cable TV. It appears the slower speed is only in the one bedroom so I imagine that's down to the Wi-Fi. That's a bit surprising because it's a really good router. I'll try logging in on another browser on my phone instead of the laptop, thanks
Jul 20, 2020Guru - Experienced User
If its only over wifi, then its a router issue. The CM1150V doesn't have an integrated router. its a modem only.
