dinosoar
Mar 22, 2022Follower
CM400 &smart tv, when channel changing, image focus delay
Hello. 1st timer...SCHWING! Ever since COMCAST upgraded my internet performance package from25Mb to 50 Mb, my Samsung smart tv (mfd. 2107) has an image focus delay (3-9 seconds )when changing from...
Mar 22, 2022Guru - Experienced User
What samsung smart tv is it?
are you actually getting the 50mbps you're paying for since the upgrade? (did you test the speeds)
Also, if you hardwire the tv directly into the modem, is it better? (need to power off modem and tv, power modem back on with nothing connected to it, then connect the tv to it)
Reason I ask is some tv's can tell what bandwidth you have available and adjust the quality of streaming based on the speeds you have available. If 25mbps was to slow for their 4k content, the 1080P would load faster. Now that you have 50mbps, maybe its picking that up and trying to load 4k content
