jfrentas
Mar 17, 2016Follower
forgot router login password
forgot my password to log in how do i got about recovering it?
- Mar 18, 2016
Hello jfrentas
The only way to recover it is do a factory reset on the device this will lose all settings you have set up. but after a factory reset the login goes back to admin and password for the credientals.
DarrenM
Maha
Nov 26, 2016Aspirant
I forget my router password and i dont know how i get new password
- DarrenMNov 28, 2016Sr. NETGEAR Moderator
Hello Maha
you will have to factory reset your router like I posted above.DarrenM
- hholstineDec 24, 2016Aspirant
I just got a new Samsung tablet & started setting it up.
When it asked for the WiFi password that had been set up in 2010 I realized that I could not remember it.
I have 2 laptops & a smart TV that is using the WiFi but can't proceed with my new tablet set up without connecting it to my WiFi network.
Help, what can I do???
- DarrenMDec 28, 2016Sr. NETGEAR Moderator
Hello hholstine
Go to a device that is connected to the wifi and then go to www.routerlogin.net then it will prompt you with a login use admin/password then you should be able to go to the wireless settings and see your password.
DarrenM
