jfrentas
Mar 17, 2016Follower
forgot router login password
forgot my password to log in how do i got about recovering it?
- Mar 18, 2016
Hello jfrentas
The only way to recover it is do a factory reset on the device this will lose all settings you have set up. but after a factory reset the login goes back to admin and password for the credientals.
DarrenM
DarrenM
Nov 28, 2016Sr. NETGEAR Moderator
Hello Maha
you will have to factory reset your router like I posted above.
DarrenM
hholstine
Dec 24, 2016Aspirant
I just got a new Samsung tablet & started setting it up.
When it asked for the WiFi password that had been set up in 2010 I realized that I could not remember it.
I have 2 laptops & a smart TV that is using the WiFi but can't proceed with my new tablet set up without connecting it to my WiFi network.
Help, what can I do???
- DarrenMDec 28, 2016Sr. NETGEAR Moderator
Hello hholstine
Go to a device that is connected to the wifi and then go to www.routerlogin.net then it will prompt you with a login use admin/password then you should be able to go to the wireless settings and see your password.
DarrenM
