Susiesundberg
Oct 05, 2022Follower
Activation of extender
I purchased the Netgear extender WH3000 RP in 2014. I was able to activate it and it worked very well. On Oct 4 2022 I had a new internet installed ATT Fiber Optics. The extender disconnected and I d...
Oct 06, 2022Guru - Experienced User
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
