techfugitive
Apr 11, 2018Tutor
Android Genie App
So I have checked the Genie app on Android and IOS. Here is the scenario: I am away from my network and am Remotely Connected over the WAN. Access control is on I click Network Map On IOS, ...
- Apr 21, 2018
The complete Genie App and Program design is a Netgear Nightmare.
Windows (and macOS when I have it right) Genie - with a Remote Connection to a Nighthawk - does always show the local (W)LAN devices and in no way the Network Map aka. Attached Devices on the Nightawk router "out there". And yes, my Genie on Android (v3.1.52) connected remotely to a R9000 (v1.0.3.16) does only show the R9000, the "cloud", and the mobile running the Genie App.
Now they hope to make things better closing the Genie forum here in the community, and having everyhting in the Nighthawk App forum. Ridiculous again.
schumaku
Apr 21, 2018Guru - Experienced User
techfugitive
Apr 21, 2018Tutor
Thanks, it's always relieving to know it's not my particular device with the problem.
- schumakuApr 21, 2018Guru - Experienced User
Thank you for the kudos techfugitive ... however marking this as a solution is a little bit over-jealous 8-)
- techfugitiveApr 21, 2018TutorLOL the app is being mothballed. you have me the fix, I have to get an iPhone and use the iOS app😫
techfugitive wrote:
LOL the app is being mothballed. you have me the fix, I have to get an iPhone and use the iOS app😫Would love to mark this answer as a solution here! It does indeed work here on iOS.
