Astroprojector
Jul 12, 2020Guide
Cannot aceess Readyshare folder. Error 0x80004005
I connected an external hardrive via the USB port to the router. Its not a new connection I have been able to successfully access the drive before. However, after the last firmware update I cannot access it anymore. When I try to access the drive using \\readyshare\folder, I get an error 0x80004005. I tried connectiong using \\readyshare.routerlogin.net, I get the login dialog with Admin as a user name and blank password. I have no idea why I am being asked the password and I do not know what it is. I tried using the router login password, but it did not work.
Any ideas how to fix this?
1 Reply
- c_palInitiate
I had a similar issue for my work NAS. My supervisor had me edit a registry, rebooted and it immediately worked.
In regedit:
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\LanmanWorkstation\Parameters
Create a new DWORD called "AllowInsecureGuestAuth" and set the value to 1
after a reboot, worked like a charm. Hope this helps, took us forever to figure it out.
