LorenzoAATE
Aug 31, 2019Aspirant
Can't log into genie
Hi everyone, I'm new here and hope someone can help. I can't log in into the Genie APP because I don't have a password. It says the default password is "password", but it doesn't work. I've also trie...
- Sep 02, 2019
It's the same admin account password as configured on the router. As a D7000 does unlikely work straight away from the box (some basic config is required, e.g. DSL settings, carrier authentication, ...) I suspect that the default password was changed before.
This is the same password you use to login on the router Web interface e.g. when using routerlogin.net .
LorenzoAATE
Sep 02, 2019Aspirant
I try to log in, for example, to change the router settings and it asks me for a password I don't have and the suggested default "password" doesn't work.
This is the Genie APP I downloaded from Netgrear's website for Windows (7)
schumaku
Sep 02, 2019Guru - Experienced User
