LorenzoAATE
Aug 31, 2019Aspirant
Can't log into genie
Hi everyone, I'm new here and hope someone can help. I can't log in into the Genie APP because I don't have a password. It says the default password is "password", but it doesn't work. I've also trie...
- Sep 02, 2019
It's the same admin account password as configured on the router. As a D7000 does unlikely work straight away from the box (some basic config is required, e.g. DSL settings, carrier authentication, ...) I suspect that the default password was changed before.
This is the same password you use to login on the router Web interface e.g. when using routerlogin.net .
schumaku
Sep 02, 2019Guru - Experienced User
LorenzoAATE
Sep 02, 2019Aspirant
Thanks man, didn't try old passwords before... I changed it the first time (months ago) and forgot it. Tried a couple of old passwords and it worked.
Thank again.
