ulfhedinn
Jan 04, 2017Tutor
Cant login to openDNS from genie
Hello, I bought this router a few months ago and set everything up including LPC just fine. It was working for awhile but sometime during then and now it stopped filtering correctly. When I log...
- Jan 09, 2017
I was able to resolve this on my own. I ended up doing a factory reset to resolve this. The odd part is I set it up the exact same way as it was previously setup. Wish I would have figured out what the culprit was.
DexterJB
Jan 09, 2017NETGEAR Moderator
ulfhedinn
Jan 09, 2017Tutor
- DexterJBJan 09, 2017NETGEAR Moderator
- etmaniacJan 15, 2017Aspirant
Hi,
I have exactly the same issue. No longer able to turn on parental controll via Genie, complaining about network connectivity. OpenDNS account active and working, internet is just fine. Without Genie not able to differentiate security levels for clients. Obviously the traffic is still pointed to the openDNS servers and I have ensure that the OpenDNS client is installed on one of our mac's to ensure the proper IP address is used by openDNS.
Any resolutions to the problem? seems to be a software issues with lots of customers raising the issue. BTW, another thing I miss in this newly bought router is time based access per MAC address..
thx
- DexterJBJan 15, 2017NETGEAR Moderator
Hi etmaniac,
Please try the following steps.
1. Try using another device to login to your OpenDNS account via NETGEAR Genie.
2. Make sure you are able to login to your account via https://netgear.opendns.com/sign_in.php.
3. Try uninstalling and re-installing the Genie programs/apps from your devices.
4. If the issue persists, you can perform a factory reset.
Dexter
Community Team
