ulfhedinn
Jan 05, 2017Tutor
Cant login to openDNS from genie
Hello, I bought this router a few months ago and set everything up including LPC just fine. It was working for awhile but sometime during then and now it stopped filtering correctly. When I log...
- Jan 09, 2017
I was able to resolve this on my own. I ended up doing a factory reset to resolve this. The odd part is I set it up the exact same way as it was previously setup. Wish I would have figured out what the culprit was.
ulfhedinn
Mar 08, 2017Tutor
So it happened again, twice since this post. No changes made at all but parental controls stop working, whenever you try to goto reenable it it just stalls at logging in. The only fix I have found is to factory reset and reload saved configuration(which never changes). It seems to happen after frimware upgrades but im not 100% sure. its pretty annoying though.
