Shuttlecock97
Sep 18, 2022Follower
Cant reset admin password on R6900v2
When trying to log in, it doesn’t accept any passwords. It then asks for my serial number and two security questions. Then it takes me to the password reset page. When I try resetting the admin password for my router, it says that “Each answer should be min 1 and max 64 alpha-numeric characters, space is allowed too”. I am well within those numbers and have even tried using the current questions just to see if I would still get it. I still do, anyone know why?
Try factory resetting the router by pressing the reset button then walk thru the setup wizard using a wired PC and web browser. Be sure to write down all important information for safe keeping.
Shuttlecock97 wrote:
When trying to log in, it doesn’t accept any passwords. It then asks for my serial number and two security questions.Did you ever tell the router the answers to those questions?
Netgear makes life interesting by having all manner of passwords. There is the one into the router's controls, then there are those to get into the router's wifi, and then there any that you use to get into this Community and/or MyNetgear.
Different passwords pop up at different times, depending on how you connect to the device and where you are trying to access from, your local network or somewhere else on the Internet. (Previously known as Remote Access, that's now called Anywhere Access.)
If you are talking about access to the browser's graphical user interface (GUI), the router's controls, these are on the label for your device, along with the default wifi login details. The username is fixed at admin. The default password is password.
If you are trying to use the "password recovery" option, there is a bug in Netgear's implementation of password recovery on some devices. You can get locked into a closed loop.
If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process. If you haven't already given the thing your personal answers, they are not in its memory and it has no way of knowing if they are correct.
If the standard factory password (password) does not work, then you will have to factory reset the thing to get back to that. Then either disable password recovery (check the manual for your device) or provide some answers to those questions.How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
