glenintenn's avatar
glenintenn
Change a client machine's DHCP-assigned IP address? (ipconfig /release - /renew has no effect)
Greetings,    I've been trying to update the ip address on a specific machine in my home network.    It's currently set at 192.x.x.8 (autoassigned when it first joined the network).    I've set...
  • glenintenn's avatar
    glenintenn
    Nov 30, 2022
    Nuclear option worked:
    1. Hard code the ethernet adapter to the new, desired IP address.  Reboot machine. confirm it is ping-able at the new address.
    2. confirm the client PC IP address is listed in the reserved IP address at the desired IP (e.g. the one hard coded at the client).  Reboot the netgear router
    3. confirm the client PC is still accessible at the new ip address
    4. switch the client PC back to DHCP.  Reboot the client PC
    In my case the client PC came back up at the newly assigned IP address (which had previously (several days ago) been reserved for the new client PC's MAC Address)
    My conclusion: the Netgear router provides no software / admin UI to clear the ARP cache and so ... by setting the client PC to the new IP address already set in the Reserved IP list and then rebooting the router, the new IP and mapping to MAC address was finally honored.
    Other thoughts welcomed.
