kellydawson17_
Apr 22, 2022Follower
Change password on Wi-Fi can’t seam to connect to change back to factory setting.
michaelkenward
Apr 24, 2022Guru - Experienced User
That subject could mean many things?
How about explaining what you are doing and where it goes wrong?
It also helps if we know which Netgear devices you are playing with.
Meanwhile, manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Look for the model number on the label on the device.
