Aparose1957
Jan 30, 2024Follower
Connecting comcast
Ok I downloaded it and it says it is connected to the internet and I can not get into internet explorer it say it is not compatible with it! Can I get on the internet or not. It is frustrating. Thanks
michaelkenward
Jan 31, 2024Guru - Experienced User
What are you trying to connect? A Netgear router of some sort?
Internet explorer, a long dead browser, doesn't have to be "compatible" with your router.
What are you doing and what happens? Where do you see these messages and what do they say? The exact wording matters.
