Missblack's avatar
Missblack
Follower
Oct 08, 2018
D6000 NBN connection issues
I have a D6000. I have recently connected to HFC NBN, according to netgear this device should be compatible. I have gone through this https://kb.netgear.com/27029/How-to-connect-the-D6000-to-a-Cable-F...
  • schumaku's avatar
    Oct 09, 2018
    The DSL Modems and Routers community area would be better suited for your router model as this is unrelated to the Genie App (on mobile phones) resp Genie program (macOS, Windows).
