reddwarf4ever
Apr 08, 2019Aspirant
D6400 Remote access to configure for high speed fibre
Hello
have installed genie app on my iPad , with the intention to remote connect to my friends router to help optimise it.....can this be done ? Or must I be within Wi-fi range of my friends router...
- Apr 09, 2019
Had hoped that someone with knowledge of this router could help me, but alas I was wrong.
this post can be closed now
schumaku
Apr 08, 2019Guru - Experienced User
reddwarf4ever wrote:
have installed genie app on my iPad , with the intention to remote connect to my friends router to help optimise it.....can this be done ? Or must I be within Wi-fi range of my friends router ?
Permitting the D6400 does support remote App access - somebody with local [W]LAN access must - using the Genie - enable the App remote administration, and register it to (yor friends) [My]Netgear Account. If he does trust in you, there is no other way than sharing the credentials for the Netgear Account, logout in the Genie App in case you are logged in to your own account, the login to your friends Netgear Account - in the Remote you have his router
are there specific settings for the d600 to work with fast fibre ?
No experience with this model I'm afraid.
- reddwarf4everApr 08, 2019Aspirant
Sorry but that reply wasn’t any help whatsoever..
- schumakuApr 08, 2019Guru - Experienced User
So please read it again, and tell me what you haven't understood.
have installed genie app on my iPad , with the intention to remote connect to my friends router to help optimise it.....can this be done?
Yes.
No. You just can't "just" install the App and connect to any router if the router was not configured for the App remote administration while connected on the [W]LAN. Beyond, the routers App Remote Administration can only be enabled for one [My]Netgear Account. Nothing I have not talked about before.
- reddwarf4everApr 09, 2019Aspirant
The description of the app says allows remote access, my understanding was it had the same facilities as team viewer, but netgear means, within the Wi-fi range of the router.....there’s remote and there’s remote.....
think all all I need to know is would I benefit from changing the settings to improve performance with fast fibre ?
