Felicia86
Jan 04, 2019Tutor
Finding IP addresses
I have so many new IP addresses on my map on genie app since Christmas. How do I find out what device they belong too? Not able to pause them. Some I believe are not a computer nor phone.
- Jan 10, 2019
Hi Felicia86,
Welcome to the community!
You can try accessing the router UI and check on the attached devices list for a detailed look on the attached devices. You can also try changing the WiFI password if you are looking to connect only the devices that you use. The links below may help.
http://kb.netgear.com/app/answers/detail/a_id/980
http://kb.netgear.com/app/answers/detail/a_id/24096
Dexter
Community Team
DexterJB
Jan 14, 2019NETGEAR Moderator
Hi Felicia86,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Felicia86
Jan 27, 2019Tutor
Yes, I am still having same problem. It never improved. I still have so many IP numbers shown that is connected to router. If you try to pause it wont and it wont allow you to change the name of it.
