vickyrao
Jun 15, 2017Star
GENIE APP ON IOS AND ANDROID FAILED TO LOGIN
REFER: https://community.netgear.com/t5/Genie/Can-t-login-to-router-via-Genie/m-p/1303462#M6085 Many of us are having issues logging on to Genie App on Netgear Nighthawk X6 R8000. Since there was...
- Aug 10, 2017
Agreed. I have also updated my firmware to 1.0.3.48 and Genie app on Android and iOS is functioning again. Locally and Remotely it works without flaws. Finally this is sorted out.
Jmisheal
Jun 20, 2017Initiate
I have the exact same issue. If I reset or reboot my router the app works for a short time. Then I get this annoying error. I have to reboot the router every time I need to login via the genie app. Really frustrating. I don't want to go back to an older firmware. Netgear really needs to fix this issue before I toss this router in the garbage.
- vickyraoJun 20, 2017Star
Yeah. I am still waiting for them to give me a call back. Once I have some update from them, i will update here as well.
