vickyrao
Jun 15, 2017Star
GENIE APP ON IOS AND ANDROID FAILED TO LOGIN
REFER: https://community.netgear.com/t5/Genie/Can-t-login-to-router-via-Genie/m-p/1303462#M6085 Many of us are having issues logging on to Genie App on Netgear Nighthawk X6 R8000. Since there was...
- Aug 10, 2017
Agreed. I have also updated my firmware to 1.0.3.48 and Genie app on Android and iOS is functioning again. Locally and Remotely it works without flaws. Finally this is sorted out.
ScubaMike7
Jun 20, 2017Star
I see this http://imgur.com/a/6W9TN
"netgear router not found or is not supported. Make sure that your mobile device is not connected to the router's guest network and that IPv6 is not enabled”
Nighthawk X6 R8000
V1.0.3.36_1.1.25
