vickyrao
Jun 15, 2017Star
GENIE APP ON IOS AND ANDROID FAILED TO LOGIN
REFER: https://community.netgear.com/t5/Genie/Can-t-login-to-router-via-Genie/m-p/1303462#M6085 Many of us are having issues logging on to Genie App on Netgear Nighthawk X6 R8000. Since there was...
- Aug 10, 2017
Agreed. I have also updated my firmware to 1.0.3.48 and Genie app on Android and iOS is functioning again. Locally and Remotely it works without flaws. Finally this is sorted out.
Willard395
Jul 11, 2017Tutor
Johnny2020 This issue has been resolved. I was able to log into my router from my iPhone and iPad this morning without restarting the router. I should also note I had a stronger signal and range over all my devices. Well done Netgear! I was about to return this router and buy a Linksys. Keenup the good work!
