vickyrao
Jun 15, 2017Star
GENIE APP ON IOS AND ANDROID FAILED TO LOGIN
REFER: https://community.netgear.com/t5/Genie/Can-t-login-to-router-via-Genie/m-p/1303462#M6085 Many of us are having issues logging on to Genie App on Netgear Nighthawk X6 R8000. Since there was...
- Aug 10, 2017
Agreed. I have also updated my firmware to 1.0.3.48 and Genie app on Android and iOS is functioning again. Locally and Remotely it works without flaws. Finally this is sorted out.
Johnny2020
Aug 07, 2017Aspirant
Installed latest update .48 and the Genie app works. Thank you Netgear for listening and fixing the software for the Genie app. Whoooo hoo
vickyrao
Aug 10, 2017Star
- HippogriffAug 13, 2017Aspirant
Hi,
I have R6220 router, and I tried all that is mentioned in the solution thread. But still not able to login to the Genie ios app. I'm providing the correct credentials, but don't know what's the problem. Please help. Thanks!
vickyrao wrote:Agreed. I have also updated my firmware to 1.0.3.48 and Genie app on Android and iOS is functioning again. Locally and Remotely it works without flaws. Finally this is sorted out.
