grumpybs
Aug 12, 2015Tutor
genie installer/updater not windows 10 compatable
I upgraded to Windows 10 and had netgear genie installed at the time. Genie worked just fine on Win 10 until I tried to upgrade to the newest version of genie. The installer deleted the old version a...
- Sep 02, 2015
Hi grumpybs,
The latest version of the NETGEAR Genie should be compatible with Windows 10. I suggest making sure that the program has been completely uninstalled by checking Programs and Features under Control Panel. You can then try to reinstall the program by downloading the latest version using he link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
Art_Uro
Nov 23, 2015Tutor
Hi Dexter and others one. Some days ago Microsoft installed the last update for the tablet Surface Pro 3, from Windows10 Home, to Windows 10 Pro. I had the 2.4.12 version installed of Genie, and it continued running ok.
Today I've tested the 2.4.14 install and don't run, crash. It give the usual error.
After uninstallation of 2.4.14 I've reinstalled the 2.4.12 version of Genie, and it run again ok.
Thanx.
