grumpybs
Aug 12, 2015Tutor
genie installer/updater not windows 10 compatable
I upgraded to Windows 10 and had netgear genie installed at the time. Genie worked just fine on Win 10 until I tried to upgrade to the newest version of genie. The installer deleted the old version a...
- Sep 02, 2015
Hi grumpybs,
The latest version of the NETGEAR Genie should be compatible with Windows 10. I suggest making sure that the program has been completely uninstalled by checking Programs and Features under Control Panel. You can then try to reinstall the program by downloading the latest version using he link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
highdef2012
Dec 10, 2015Tutor
Had a problem with my laptop, so had to reload Windows 8.1 as well as the Windows 10 "update".
Now, as others have mentioned, my Netgear Genie is no long working and is having compatibility issues.
I've tried running compatibility with Windows 7, 81. and 10 and none will allow access even after removing/
reinstalling 12 times.
I sure miss the Genie, and hopefully you folks at Netgear can get us back to enjoying it again.
- uffgnu14Dec 11, 2015Luminary
Hi
I'm, like "highdef2012 2015-12-10 02:38 PM" getting "Stopped working" with new Genie 2.4.18
on windows 10 Home.
Ulf
- DexterJBDec 12, 2015NETGEAR Moderator
Hi highdef2012 and uffgnu14,
Please try installing the latest version (2.4.20) of the NETGEAR Genie program and check if it works.
Dexter
Community Team
- ThinusDec 12, 2015Star
Makes no difference - still the same crash after running the program. I have now tried all versions from .12 to this latest one in all compatability modes.
Crashes both my Alienware W10 machines
Thinus
