grumpybs
Aug 12, 2015Tutor
genie installer/updater not windows 10 compatable
I upgraded to Windows 10 and had netgear genie installed at the time. Genie worked just fine on Win 10 until I tried to upgrade to the newest version of genie. The installer deleted the old version a...
- Sep 02, 2015
Hi grumpybs,
The latest version of the NETGEAR Genie should be compatible with Windows 10. I suggest making sure that the program has been completely uninstalled by checking Programs and Features under Control Panel. You can then try to reinstall the program by downloading the latest version using he link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
DexterJB
Dec 12, 2015NETGEAR Moderator
Hi highdef2012 and uffgnu14,
Please try installing the latest version (2.4.20) of the NETGEAR Genie program and check if it works.
Dexter
Community Team
highdef2012
Dec 12, 2015Tutor
... i copied and pasted the Genie edition you mentioned, then Googled it.
It came up with a chip.de website. I went there, downloaded it and got the same
Windows error message. Here's a capture of the download version I used.
