grumpybs
Aug 12, 2015Tutor
genie installer/updater not windows 10 compatable
I upgraded to Windows 10 and had netgear genie installed at the time. Genie worked just fine on Win 10 until I tried to upgrade to the newest version of genie. The installer deleted the old version a...
- Sep 02, 2015
Hi grumpybs,
The latest version of the NETGEAR Genie should be compatible with Windows 10. I suggest making sure that the program has been completely uninstalled by checking Programs and Features under Control Panel. You can then try to reinstall the program by downloading the latest version using he link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
highdef2012
Dec 12, 2015Tutor
... I found a weird work around. The one link the Rep posted was for a cell phone APK. I decided to install the Genie app from the Play Store on my new Note 5. It's not a desktop version, but shows me 95% of the same things about my home network. Guess it'll have to do. I've never had a **bleep**tier product support than this Netgear doofus. Lemme know how you make out.
