grumpybs
Aug 12, 2015Tutor
genie installer/updater not windows 10 compatable
I upgraded to Windows 10 and had netgear genie installed at the time. Genie worked just fine on Win 10 until I tried to upgrade to the newest version of genie. The installer deleted the old version a...
- Sep 02, 2015
Hi grumpybs,
The latest version of the NETGEAR Genie should be compatible with Windows 10. I suggest making sure that the program has been completely uninstalled by checking Programs and Features under Control Panel. You can then try to reinstall the program by downloading the latest version using he link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
Nick-B
Dec 13, 2015Aspirant
Just installed Windows 10 cumulative update and guess what?
Netgear Genie has been removed from my system as incompatable with this versin of Windows. :-(
When is there going to be a fix for this?
gailparz
Hi! This happened to me on the last update of Windows. Revert back to the previous build and give the reason that programs aren't working with the new update. You might have to reinstall the previous version of genie.
