grumpybs
Aug 12, 2015Tutor
genie installer/updater not windows 10 compatable
I upgraded to Windows 10 and had netgear genie installed at the time. Genie worked just fine on Win 10 until I tried to upgrade to the newest version of genie. The installer deleted the old version a...
- Sep 02, 2015
Hi grumpybs,
The latest version of the NETGEAR Genie should be compatible with Windows 10. I suggest making sure that the program has been completely uninstalled by checking Programs and Features under Control Panel. You can then try to reinstall the program by downloading the latest version using he link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
carll76
Dec 13, 2015Apprentice
I have tried to update to .20 today. Through the Genie app and by uninstalling .12 and installing .20..
It doesnt work, same error message. Reverted to a saved version of .12 and its working again.
Gerry_SA
Dec 20, 2015Tutor
Hi Carll76,
I now have .20 working fine!
I'd like to see you with the latest version working too - please try my idea on this page - message 137.
Uninstall your old version first...
Let me know how you go.
