grumpybs
Aug 12, 2015Tutor
genie installer/updater not windows 10 compatable
I upgraded to Windows 10 and had netgear genie installed at the time. Genie worked just fine on Win 10 until I tried to upgrade to the newest version of genie. The installer deleted the old version a...
- Sep 02, 2015
Hi grumpybs,
The latest version of the NETGEAR Genie should be compatible with Windows 10. I suggest making sure that the program has been completely uninstalled by checking Programs and Features under Control Panel. You can then try to reinstall the program by downloading the latest version using he link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
LtScythe
Feb 01, 2016Guide
Alright so after some time fiddling around with it I was finally able to get an older version of genie to work with the Driver trick you showed in a previous post, but now its saying that my router is not supported, but when I check the list its on there. I have the Nighthawk AC3200 R8000, is there any way to get around this?
BelmontJohnny
Feb 02, 2016Aspirant
Was there any response or resolution to this? Have the same issue.
- DexterJBFeb 02, 2016NETGEAR Moderator
Hi @LtScythe,
I was able to do my own test and did not encounter any errors. Please make sure that the router is using the latest firmware. If it is, try performing a firmware re-flash then reset and reconfigure the device. You may find some helpful links below.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
- LtScytheFeb 10, 2016Guide
And again you aren't understanding the fact that your little web login page doesnt work for me, your router login page not available, use IP Adress, **bleep** is unavailable, I am sick of playing this back and forth game, Netgear get your **bleep** together and fix the F****** problem, enough workarounds this is unacceptable, keep going this route you'll end up like D-Link, and your customers will take their business elsewhere.
Hi @Nr7000,
1. Have you tried the temporary work around of replacing the drivers of the new version of the NETGEAR Genie program?
2. You can still perform the firmware update without the NETGEAR Genie program. You may refer to the links below for the steps.
3. The cause of the issue was just recently discovered. The fix is currently being worked on by engineering.
Dexter
Community Team
- Nr7000Feb 02, 2016Aspirant
Hi Dexter,
I spoke to technical support and he told me to just log directly onto the router and do the firmware update from there. The software is in the router. I just deleted the Genie software and when I get notification through email I will log on directly.
- mjpanicaliFeb 06, 2016Aspirant
This is really unacceptable. I may very well return the router to Amazon as the junk isn't working. Amazon can work it out with Netgear. Perhaps a few 1 star ratings will get their attention.
Hi @BelmontJohnny,
I have provided a response on your post from the other thread.
https://community.netgear.com/t5/Genie/Netgear-Genie-Crashes/td-p/966767/page/5
Dexter
Community Team
