grumpybs
Aug 12, 2015Tutor
genie installer/updater not windows 10 compatable
I upgraded to Windows 10 and had netgear genie installed at the time. Genie worked just fine on Win 10 until I tried to upgrade to the newest version of genie. The installer deleted the old version a...
- Sep 02, 2015
Hi grumpybs,
The latest version of the NETGEAR Genie should be compatible with Windows 10. I suggest making sure that the program has been completely uninstalled by checking Programs and Features under Control Panel. You can then try to reinstall the program by downloading the latest version using he link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
DcSpirou
Feb 06, 2016Aspirant
Hello to all and to all, please excuse my English because this is a translation. I have myself a problem with Netgear Genie whose several versions I tried (of 2.4.12 to the last version 2.4.20). My problem is not an error of launch of the program which dashes(launches) him(her) very well, only concerns(marigolds), it is that when is I restart the PC or if I him(her,it) put out(switched off) and relights him(it), Netgear Genie does not dash(launch) any more in the starting up. Thank you if somebody knows the problem, I am under Windows 10 Professional 64 Bits.
I forgot to tell you that I have R7000 and that with Windows 8.1 it worked very well, but since I installed Windows 10 there partition and formating my SSD, Netgear Genie launches well but does not launch automatically in the restart or by putting out(switching off) the PC and relighting him(it) later or later.
Cordially
