grumpybs
Aug 12, 2015Tutor
genie installer/updater not windows 10 compatable
I upgraded to Windows 10 and had netgear genie installed at the time. Genie worked just fine on Win 10 until I tried to upgrade to the newest version of genie. The installer deleted the old version a...
- Sep 02, 2015
Hi grumpybs,
The latest version of the NETGEAR Genie should be compatible with Windows 10. I suggest making sure that the program has been completely uninstalled by checking Programs and Features under Control Panel. You can then try to reinstall the program by downloading the latest version using he link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
Retired_Member
Mar 20, 2016Hi,
Can someone please give me a donwload link to a version that works!!!
Every time I open the program even in windows compatibility mode, it crashes.
Thanks
- DexterJBMar 20, 2016NETGEAR Moderator
Hi @aswerdlow1,
You may refer to the steps below instead.
1. Install the latest version of NETGEAR Genie. You may use the download link below.
2. Once you have successfully installed the program, navigate to C:\Program Files (x86)\NETGEAR Genie\bin
3. Delete the drivers folder.
4. Download the drivers for the previous version of NETGEAR Genie using the download link below.
https://drive.google.com/file/d/0Bz-pjmQaYmk6Z0xTX3d3SVFLZ0k/view?usp=sharing
5. Unzip the file to your preferred location (Desktop would be easy to locate). It will contain the drivers folder.
6. Copy the drivers folder that you have just unzipped and navigate back to C:\Program Files (x86)\NETGEAR Genie\bin
7. Paste the drivers folder.
8. Relaunch the NETGEAR Genie programRegards,
Dexter
Community Team
