grumpybs
Aug 12, 2015Tutor
genie installer/updater not windows 10 compatable
I upgraded to Windows 10 and had netgear genie installed at the time. Genie worked just fine on Win 10 until I tried to upgrade to the newest version of genie. The installer deleted the old version a...
- Sep 02, 2015
Hi grumpybs,
The latest version of the NETGEAR Genie should be compatible with Windows 10. I suggest making sure that the program has been completely uninstalled by checking Programs and Features under Control Panel. You can then try to reinstall the program by downloading the latest version using he link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
wgblondel
May 20, 2016Aspirant
Hi.
I try to install Netgear Genie on a Windows 10 64bit machine but the installer won't run.
I downloaded it multiple times from Netgear's website on multiple computer but I have the same error every time.
"NSIS Error
Installer integrity check has failed. Common causes include incomplete download and damaged media. Contact the installer's author to obtain a new copy."
Please fix that.
