grumpybs
Aug 12, 2015Tutor
genie installer/updater not windows 10 compatable
I upgraded to Windows 10 and had netgear genie installed at the time. Genie worked just fine on Win 10 until I tried to upgrade to the newest version of genie. The installer deleted the old version a...
- Sep 02, 2015
Hi grumpybs,
The latest version of the NETGEAR Genie should be compatible with Windows 10. I suggest making sure that the program has been completely uninstalled by checking Programs and Features under Control Panel. You can then try to reinstall the program by downloading the latest version using he link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
lobosmm
Jun 10, 2016Aspirant
Genie 1.2.0.10
Windows 10
I'm trying to uninstall Genie as it is constantly eating 60% of the CPU. Uninstall fails and reports the uninstaller is incompatible with the OS
JuanEdo88
Jun 15, 2016Aspirant
Put your Netgear model at this link http://www.netgear.com/support/?cid=gwmng then download the programm
