grumpybs
Aug 12, 2015Tutor
genie installer/updater not windows 10 compatable
I upgraded to Windows 10 and had netgear genie installed at the time. Genie worked just fine on Win 10 until I tried to upgrade to the newest version of genie. The installer deleted the old version a...
- Sep 02, 2015
Hi grumpybs,
The latest version of the NETGEAR Genie should be compatible with Windows 10. I suggest making sure that the program has been completely uninstalled by checking Programs and Features under Control Panel. You can then try to reinstall the program by downloading the latest version using he link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
Kaveh300
Aug 14, 2015Aspirant
My genie app worked after I upgraded to Windows 10, did you uninstall the Genie App before reinstalling it?
grumpybs
Aug 28, 2015Tutor
No I didn't uninstall first. I assume the genie software update process takes care of itself. Genie worked after the windows 10 update but when the genie update ran it deleted the old genie and crashed installing the new version. Windows reports that the software being installed is incompatable.
- DexterJBSep 02, 2015NETGEAR Moderator
Hi grumpybs,
Dexter
Community Team
- grumpybsOct 04, 2015Tutor
I did delete genie in the control panel and it still failed. I went back and deleted everything on the pc that had 'netgear' in it except my internet favorites (not in the registry either). Made sure it did not show in the control panel. Downloaded the current version from the web site today and installed it without any problem. There have been many windows updates since I tried last. The version of Genie that installed ir 2.4.16.
I'm calling this fixed for me.
Bob
- tomdaltonzOct 05, 2015Star
Definately a bug in this new update, as I have had the same issue as well. Genie worked fine before installing the update, now it crashes every time I try to run it, saying there was an error and that Windows will notify me when the problem is fixed.
Using WNDR3400v3
- Art_UroOct 11, 2015Tutor
Sorry Dexter, but the problem continue in surface 3 pro windows 10, with the last update form genie download, 5 minutes ago.
I cleaned the register in windows 10 looking for "netgear genie" and delete, and the problem continue after instalation.
Thanhx.
- DexterJBOct 12, 2015NETGEAR Moderator
Hi Art_Uro, Nr7000, Jrev, kimella,
Please indicate the devices (brand and model) that experience the issue since I will collate the information to send an inquiry to Engineering. This is a bit odd since other Windows 10 devices are able to run the NETGEAR Genie program just fine. This will help us isolate the issue.
Dexter
Community Team
- SaminncOct 24, 2015Aspirant
I am having the same problem (10/24/2015). Genie was working fine, even after the Win 10 install. Was in Genie and it said a new version was available which supports Win 10. Did the install, no joy. Deleted all versions, re-downloaded - no joy. What's a person supposed to do, if a simple network "Genie" device doesn't work? Are you going to fix the problem?
- DexterJBOct 26, 2015NETGEAR Moderator
Hi Saminnc,
We sincerely apologize for the inconvenience. Rest assured, we are working on a fix for this. In the mean time, you can use the download link below for the previous version (2.4.12) of the NETGEAR Genie.
http://files.netgear-support.com/go/?a=d&i=4KoWqtKssb
Dexter
Community Team
