grumpybs
Aug 12, 2015Tutor
genie installer/updater not windows 10 compatable
I upgraded to Windows 10 and had netgear genie installed at the time. Genie worked just fine on Win 10 until I tried to upgrade to the newest version of genie. The installer deleted the old version a...
- Sep 02, 2015
Hi grumpybs,
The latest version of the NETGEAR Genie should be compatible with Windows 10. I suggest making sure that the program has been completely uninstalled by checking Programs and Features under Control Panel. You can then try to reinstall the program by downloading the latest version using he link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
grumpybs
Aug 28, 2015Tutor
No I didn't uninstall first. I assume the genie software update process takes care of itself. Genie worked after the windows 10 update but when the genie update ran it deleted the old genie and crashed installing the new version. Windows reports that the software being installed is incompatable.
DexterJB
Sep 02, 2015NETGEAR Moderator
Hi grumpybs,
Dexter
Community Team
- grumpybsOct 04, 2015Tutor
I did delete genie in the control panel and it still failed. I went back and deleted everything on the pc that had 'netgear' in it except my internet favorites (not in the registry either). Made sure it did not show in the control panel. Downloaded the current version from the web site today and installed it without any problem. There have been many windows updates since I tried last. The version of Genie that installed ir 2.4.16.
I'm calling this fixed for me.
Bob
- tomdaltonzOct 05, 2015Star
Definately a bug in this new update, as I have had the same issue as well. Genie worked fine before installing the update, now it crashes every time I try to run it, saying there was an error and that Windows will notify me when the problem is fixed.
Using WNDR3400v3
- artie922Dec 21, 2015Aspirant
Bob,
where is the link to 2.4.16
i have had problems with the netgear since upgrading to windows 10. i am not computer proficient so if you can give me steps on what you did, i would really appreciate it. Thank you.
Artie
ps i cant even have guests log on to the guest password because of this as well. and get the netgear app error message when i log on to the computer and cant open the netgear genie app itself to get into settings etc
- highdef2012Dec 21, 2015Tutor
... Artie-
this may not be something you'd prefer, but I gave up and
loaded the Genie app on my Note 5 phone that I just got.
Slight pain in needing to have your phone for this, but the
app works great!
Scott
- StefanovichDec 22, 2015Aspirant
Same happens to me cannot make it work on my new system. Old system that was auto upgraded has no issues just the brand new installation fails... Any help?
- Art_UroOct 11, 2015Tutor
Sorry Dexter, but the problem continue in surface 3 pro windows 10, with the last update form genie download, 5 minutes ago.
I cleaned the register in windows 10 looking for "netgear genie" and delete, and the problem continue after instalation.
Thanhx.
- DexterJBOct 12, 2015NETGEAR Moderator
Hi Art_Uro, Nr7000, Jrev, kimella,
Please indicate the devices (brand and model) that experience the issue since I will collate the information to send an inquiry to Engineering. This is a bit odd since other Windows 10 devices are able to run the NETGEAR Genie program just fine. This will help us isolate the issue.
Dexter
Community Team
- ThinusOct 12, 2015Star
Hi Dexter
My machine is an Alienware X51 R2 running windows ten since August. I have an identical machine at work running windows 8.1. I will try and install Genie on that machine to see if the different OS makes a difference
Thinus
- SaminncOct 24, 2015Aspirant
I am having the same problem (10/24/2015). Genie was working fine, even after the Win 10 install. Was in Genie and it said a new version was available which supports Win 10. Did the install, no joy. Deleted all versions, re-downloaded - no joy. What's a person supposed to do, if a simple network "Genie" device doesn't work? Are you going to fix the problem?
- DexterJBOct 26, 2015NETGEAR Moderator
Hi Saminnc,
We sincerely apologize for the inconvenience. Rest assured, we are working on a fix for this. In the mean time, you can use the download link below for the previous version (2.4.12) of the NETGEAR Genie.
http://files.netgear-support.com/go/?a=d&i=4KoWqtKssb
Dexter
Community Team
- bn0ran01Oct 28, 2015Aspirant
DexterJB wrote:Hi Saminnc,
Dexter
Community Team
Dexter, Thank you for your link to version 2.4.12 the it worked and I now have the software installed. B
- maestro89Nov 02, 2015Aspirant
This is not a solution - this is all a lot of us see when trying to use your software after the upgrade.
- DexterJBNov 03, 2015NETGEAR Moderator
Hi maestro89,
Have you tried installing the previous version? If not, you may use the download link below.
http://files.netgear-support.com/go/?a=d&i=gRJKu6dWnB
Dexter
Community Team
- ThinusNov 03, 2015Star
Bearing in mind that no version works for some of us - refer to previous comments. I have two Dell/Alienware PCs where none of the teweaks described in all of the previous comments works
Thinus
- DenRoseNov 07, 2015Aspirant
Tried the uninstall and reinstall. The program installed but crashe when I tried to run it. I have an R7000
- DexterJBNov 09, 2015NETGEAR Moderator
Hi DenRose,
Have you tried installing the version 2.4.12? If not, you may use the download link below.
http://files.netgear-support.com/go/?a=d&i=k6XWUPGRaj
Dexter
Community Team
- gailparzNov 22, 2015Aspirant
Hi,
Net genie worked with W10 until the latest Windows upgrade that we have no control over. It's called Window 10 Insider. I received a message that Genie was removed because it was incompatible with windows 10 and to contact netgear for an update. Based on what I've been reading, nobody is able to use the genie after this latest update from windows that we have no control over.
- DexterJBNov 22, 2015NETGEAR Moderator
Hi gailparz,
It is possible that the latest Windows 10 updates do not work well with the NETGEAR Genie program. As a temporary work around, you may use the download link below for the previous version of the program.
http://files.netgear-support.com/go/?a=d&i=jlafHBVmpD
Dexter
Community Team
Thanks. I'll save the link. I went through System and went back to the previous Windows build. It put the Genie back in the program list and icon back on my desktop. It shows as being on in the task manager but the program will not open.
- DrewFromCANov 29, 2015Aspirant
Hi Dexter:
I have the same problem. I installed the genie yesterday from your website on a brand new HP laptop with factory installed Win10. No luck. Win10 program compatibility returns "incompatible program."
- DexterJBNov 30, 2015NETGEAR Moderator
Hi mrawmiller and DrewFromCA,
Please try using the download link below for the previous version of the NETGEAR Genie program.\
http://files.netgear-support.com/go/?a=d&i=mw8FeUc7cA
Dexter
Community Team
- ZobovanDec 21, 2015Aspirant
Hi,
I've got the same problem with a new install. The program stop working immediately after having started.
No compatibility options proposed by Windows is working.
What can I do with my router ?
How can I configure the router when Genie is not working ?
Stef
- Gerry_SADec 21, 2015Tutor
I'm not sure which router you have, but you don't need Genie to configure your router. You should be able to do it via the router's web page - mine for example is www.routerlogin.net.
Do you have a Quick Start book that came with it? If not, you should be able to download one from the Netgear site. You should follow the instructions in there carefully.
Genie is merely a handy tool...
Gerry
- ZobovanDec 22, 2015Aspirant
Dear Gerry,
thanks for your answer.
Obviously I can configure my router using the web interface.
However, I need to use Genie to bypass the Parental Controls settings.
Z.
- marshaDec 24, 2015Aspirant
Been using windows vista, I think 7, when we also got a laptop w/windows 10, our netgear genie says it is not enabled. Now our wifi printer doesn't work either. Would the download you suggested be okay for me to download, or would it cause more problems. Thanks for any helpful suggestions.
- brookmastDec 28, 2015Aspirant
Hi Dexter - I am also having this issue, have tried multiple de-installs and re-installs and get the same error message
- DexterJBDec 28, 2015NETGEAR Moderator
Hi brookmast,
Have you tried installing the previous version (2.4.12) of NETGEAR Genie? You may use the download link below for the installer. We are currently investigating this issue with some Windows 10 devices.
https://drive.google.com/file/d/0Bz-pjmQaYmk6Vk92eE81a20xRjg/view?usp=sharing
Dexter
Community Team
- shiroDec 28, 2015Aspirant
It worked!!!!!!!!!!!!!!Thank you very much
