grumpybs
Aug 12, 2015Tutor
genie installer/updater not windows 10 compatable
I upgraded to Windows 10 and had netgear genie installed at the time. Genie worked just fine on Win 10 until I tried to upgrade to the newest version of genie. The installer deleted the old version a...
- Sep 02, 2015
Hi grumpybs,
The latest version of the NETGEAR Genie should be compatible with Windows 10. I suggest making sure that the program has been completely uninstalled by checking Programs and Features under Control Panel. You can then try to reinstall the program by downloading the latest version using he link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
DexterJB
Oct 02, 2015NETGEAR Moderator
Hi Metrojack,
Have you tried uninstalling and re-installing the program? If not, please uninstall the program and you may use the download link below for the latest version of the NETGEAR Genie.
http://files.netgear-support.com/go/?a=d&i=eTmGNWM6Wi
Dexter
Community Team
Metrojack
Oct 02, 2015Tutor
got the email, thanks. Still the same problem.
- DexterJBOct 02, 2015NETGEAR Moderator
Hi Metrojack,
May I know what version of NETGEAR Genie you have installed? Can you also provide a screenshot of the error message?
Dexter
Community Team
- MetrojackOct 03, 2015Tutor
2.3 version
message reads; "Something caused the program to stop working and it will be shut down."
Genie actually starts-up and shows on screen for about 10 seconds before message pops up.
Everything was find before the Genie update.
I think Netgear has a bug in the update.
I looked at the Win 10 info, shows it as an App error.
- DexterJBOct 05, 2015NETGEAR Moderator
Hi Metrojack,
I recommend updating to the latest version of NETGEAR Genie which is 2.4.16. You may use the link below.
Dexter
Community Team
- cowboy2004Nov 04, 2015Aspirant
My firmware update for my Netgear Genie R6300 in October 2015 went just fine. Then Microsoft sent out two updates:
-Cumulative Update for Windows 10 for x64-based Systems (KB3105210) (Successfully installed on 11/3/2015)
-Update for Windows 10 for x64-based Systems (KB3106932) (Successfully installed on 11/3/2015)
After reboot, got the message, "This app can't run on the PC - Netgear Genie does not work on this version of Windows." Genie no longer worked saying it was not compatible to this Windows 10 version.
So yesterday (Nov 3) I restored the system back before the Windows update and Genie worked just fine again. But since, I have Windows Updates to run automatically, it again installed the above updates today and as before, Genie is no longer compatible.
So is this a Netgear problem or a Windows problem?
- DexterJBNov 05, 2015NETGEAR Moderator
Hi cowboy2004,
Thank you for providing your input regarding this situation. As it stands, we are still not able to pinpoint what is causing the issue but the additional information certainly helps us out a lot. I will forward this to the right team so that we can isolate the issue.
Dexter
Community Team
- Kelvinthegamer8Jan 26, 2016Aspirant
i have the same problem now
can you help me or can you give me a way to solve this problem
- DexterJBJan 27, 2016NETGEAR Moderator
Hi @Kelvinthegamer8,
If you are also experiencing the issue wherein the NETGEAR Genie program will stop then, you may follow the steps below.
1. Uninstall the NETGEAR Genie program from the computer/device.
2. Download the previous version (2.4.12) of the NETGEAR Genie.
Download link:
https://drive.google.com/file/d/0Bz-pjmQaYmk6Vk92eE81a20xRjg/view?usp=sharing
3. Install the program and check if it functions correctly.
4. Locate the drivers folder under C:\Program Files\NETGEAR Genie\bin and copy it to the desktop.
5. Download and install the latest version of NETGEAR Genie again using the download link below.
http://netgear.com/home/discover/apps/genie/aspx
6. Look for the same folder under the same location and delete the folder.
7. Replace the folder with the folder that you pasted on the desktop from the working version of NETGEAR Genie.
8. Close the NETGEAR Genie program through the system tray.
9. Re-open the NETGEAR Genie program and check if it works.
Dexter
Community Team
