grumpybs
Aug 12, 2015Tutor
genie installer/updater not windows 10 compatable
I upgraded to Windows 10 and had netgear genie installed at the time. Genie worked just fine on Win 10 until I tried to upgrade to the newest version of genie. The installer deleted the old version a...
- Sep 02, 2015
Hi grumpybs,
The latest version of the NETGEAR Genie should be compatible with Windows 10. I suggest making sure that the program has been completely uninstalled by checking Programs and Features under Control Panel. You can then try to reinstall the program by downloading the latest version using he link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
DexterJB
Oct 02, 2015NETGEAR Moderator
Hi Metrojack,
May I know what version of NETGEAR Genie you have installed? Can you also provide a screenshot of the error message?
Dexter
Community Team
Metrojack
Oct 03, 2015Tutor
2.3 version
message reads; "Something caused the program to stop working and it will be shut down."
Genie actually starts-up and shows on screen for about 10 seconds before message pops up.
Everything was find before the Genie update.
I think Netgear has a bug in the update.
I looked at the Win 10 info, shows it as an App error.
- DexterJBOct 05, 2015NETGEAR Moderator
Hi Metrojack,
I recommend updating to the latest version of NETGEAR Genie which is 2.4.16. You may use the link below.
Dexter
Community Team
- JrevOct 09, 2015Tutor
I followed you instructions and still did not work!
- mrawmillerNov 29, 2015Aspirant
I just tried the link and still getting the Stopped working message
- highdef2012Dec 10, 2015Tutor
... doesn't work!
- JDCboiseOct 05, 2015Initiate
Downloaded genie into Windows 10 environment for first time. Pops up for a few seconds and then it says the program has stopped working and windows will search for a solution - end of activity. Uninstalled and reinstalled with link supplied to related post No good
- kparker5555Oct 15, 2015Aspirant
I am having the same program. I have tried searching and deleting everything with "Netgear" in it and have followed all of the download links in this thread and still have the same problem. The problem is not fixed for everyone. I have a Dell Inspiron 15 3000 series laptop. Just bought with Windows 8.1 installed, did the upgrade to Windows 10. Have nothing else on the PC at this point. This was my first new software install so I don't know what could be conflicting with Netgear besides Windows 10 itself.
Please help.
- DexterJBOct 15, 2015NETGEAR Moderator
hI kparker5555,
The situation has already been brought up to Engineering. I will be providing an update to this thread as soon as I have a response.
Dexter
Community Team
- RMJhomeNov 20, 2015Aspirant
I too have precisely the same problem which occurred following a windows 10 update. Uninstall /re-install does not work!
Just tried the 'old version' fo Genie. It works.
- IcemanAzDec 09, 2015Tutor
Ive been having this exact same issue since i bought my router a couple months back. Ive called support twice and got put on hold for over twenty minutes the first time, and got hung up on the second time. This has been a really bad customer service experience so far. I gave up trying to resolve the issue over the phone so now im just looking through forums with no solution still. I keep getting the uninstall and reinstall answer but that does not work. I am also running windows 10.
- terrybassDec 09, 2015Aspirant
same thing here. Deleted everything that had anything to do with netgear genie, restarted my computer and the same thing again. As soon as it comes on the screen windows pops up and says it quit working.
Also, it works on my other computer ( I didn't update it) but now when I try to log in it says that the netgear router or it is not
not found or not supported.
- shiroDec 28, 2015Aspirant
I have the exact same problem.
Carlo
- StreetrodderJan 01, 2016Aspirant
I had the same problem that you are having. I bought a new Netgear router yesterday (December 31/'15) all worked well until I installed the "Netgear Genie" app. When I click on the app and check the box to allow this app to make changes to this computer then click ok it comes up with "This app has stopped working" message everytime!!! But I figured it out! In your web browser type www.routerlogin.net then enter admin for the username and password for the password and click OK. There ya go! I just saved it to my bookmarks and now I have access to Netgear Genie anytime I want.......Hope this helps everybody cuz I know how frustrating this can be.....ENJOY! :-)
- drrazFeb 19, 2016Aspirant
Mine does the same thing. I have a NEW computer and have never had a Netgear router before, so this was a clean install of version 2.4.16. It opens and then immediately crashes. Can't use the router so far.
- DexterJBFeb 20, 2016NETGEAR Moderator
Hi @drraz,
Have you tried performing the work around? If not, you may follow the steps below.
1. Install the latest version of NETGEAR Genie. You may use the download link below.
2. Once you have successfully installed the program, navigate to C:\Program Files (x86)\NETGEAR Genie\bin
3. Delete the drivers folder.
4. Download the drivers for the previous version of NETGEAR Genie using the download link below.
https://drive.google.com/file/d/0Bz-pjmQaYmk6Z0xTX3d3SVFLZ0k/view?usp=sharing
5. Unzip the file to your preferred location (Desktop would be easy to locate). It will contain the drivers folder.
6. Copy the drivers folder that you have just unzipped and navigate back to C:\Program Files (x86)\NETGEAR Genie\bin
7. Paste the drivers folder.
8. Relaunch the NETGEAR Genie program
Dexter
Community Team
- tamiBFeb 28, 2016Aspirant
I found that my old router WNDR 3400v2 is not compatible with Windows 10. I purchached R7000 and hoped that Genie would work but it didn't first. But I tried this method and it works!!! I really missed Genie. I also could download Gene on my Blackberry Z30. I have Surface Pro 3 upgrated to Windows 10.
