grumpybs
Aug 12, 2015Tutor
genie installer/updater not windows 10 compatable
I upgraded to Windows 10 and had netgear genie installed at the time. Genie worked just fine on Win 10 until I tried to upgrade to the newest version of genie. The installer deleted the old version a...
- Sep 02, 2015
Hi grumpybs,
The latest version of the NETGEAR Genie should be compatible with Windows 10. I suggest making sure that the program has been completely uninstalled by checking Programs and Features under Control Panel. You can then try to reinstall the program by downloading the latest version using he link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
BobP01
Oct 06, 2015Tutor
Same results as tomdaltonz Removed 2.4.16. even check registry to be sure nothing was hanging around. downloaded and installed 4.14 withe the same results. It says it's installed, even pits an icon on the desktop, opend for 5 seconds then reports it stopped and closes. If you click on the icon it installed on the desktop, it tries to reinstall istself, as if the first install never completed or was removed when the program stopped working after 5 seconds or so
carll76
Oct 06, 2015Apprentice
Sorry... I didn't see this thread (I did search but am a noob to this site)...
I tried installing 2,1.4.14 and that crashes as well now.. Surface pro 3.. Lenovo windows 10 laptop installed 2.1.4.16 no problem.
