grumpybs
Aug 12, 2015Tutor
genie installer/updater not windows 10 compatable
I upgraded to Windows 10 and had netgear genie installed at the time. Genie worked just fine on Win 10 until I tried to upgrade to the newest version of genie. The installer deleted the old version a...
- Sep 02, 2015
Hi grumpybs,
The latest version of the NETGEAR Genie should be compatible with Windows 10. I suggest making sure that the program has been completely uninstalled by checking Programs and Features under Control Panel. You can then try to reinstall the program by downloading the latest version using he link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
carll76
Oct 09, 2015Apprentice
the network map takes ages to load on my iphone...
kimella wrote:Also on my iphone I got it loaded but many of the of the pages wont load Like map ect...
kimella
Oct 09, 2015Aspirant
the only thing i can come up with is my desktop was a windows 10 upgrade my laptop came with win 10 the iphone doesnt really matter yet my tablet i havent tried yet
