grumpybs
Aug 12, 2015Tutor
genie installer/updater not windows 10 compatable
I upgraded to Windows 10 and had netgear genie installed at the time. Genie worked just fine on Win 10 until I tried to upgrade to the newest version of genie. The installer deleted the old version a...
- Sep 02, 2015
Hi grumpybs,
The latest version of the NETGEAR Genie should be compatible with Windows 10. I suggest making sure that the program has been completely uninstalled by checking Programs and Features under Control Panel. You can then try to reinstall the program by downloading the latest version using he link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
Art_Uro
Oct 11, 2015Tutor
Sorry Dexter, but the problem continue in surface 3 pro windows 10, with the last update form genie download, 5 minutes ago.
I cleaned the register in windows 10 looking for "netgear genie" and delete, and the problem continue after instalation.
Thanhx.
DexterJB
Oct 12, 2015NETGEAR Moderator
Hi Art_Uro, Nr7000, Jrev, kimella,
Please indicate the devices (brand and model) that experience the issue since I will collate the information to send an inquiry to Engineering. This is a bit odd since other Windows 10 devices are able to run the NETGEAR Genie program just fine. This will help us isolate the issue.
Dexter
Community Team
- ThinusOct 12, 2015Star
Hi Dexter
My machine is an Alienware X51 R2 running windows ten since August. I have an identical machine at work running windows 8.1. I will try and install Genie on that machine to see if the different OS makes a difference
Thinus
- ThinusOct 13, 2015Star
Ran the Genie installer on my identical Alienware machine running on w8.1 at work. Installed without any problems and can look at my network with no problems - and I don't even have a netgear router at work.
The problem on my home machine must therefore be the w10 I am running on it
- JrevOct 12, 2015Tutor
Got the Android Galaxy 6 phone and the Android Galaxy Tablet S to download Genie! Still not on the Toshiba Satellite Laptop w/ widows 10 that I just got last week!
- Nr7000Oct 21, 2015Aspirant
Hi Dexter,
My machine is a HP Envy27 all in one. I was running 8.1 PRO and updated to 10. After the update, Genie seemed to be working fine until I performed Genie update. Now when it starts up, message pops up and says that program has stopped working and explorer is closing.
Thanks
- DexterJBOct 21, 2015NETGEAR Moderator
Hi Nr7000,
Please try installing the previous versions of the NETGEAR Genie program. You can use the download link below.
http://files.netgear-support.com/go/?a=d&i=jG24n7WMuV
Dexter
Community Team
- J4UOct 22, 2015Aspirant
Thanks Dexter...the .12 works for me. The .14 didn't work nor the update to the latest on windows 10.
Still having issues logging through the opendns though. Can log onto the sight directy but obviously it is wanting me to go through the genie software to set up the parental control first. Everything else seems to function fine on .12.
Looking forward to a fix as it seems this has been occuring for some time.
Thanks for the link:
- LadyGatorOct 28, 2015Aspirant
Just got a brand new HP envy laptop with windows 10 preinstalled. My genie app was working on my prior laptop that I upgraded to windows 10 however it does not work on the new laptop. Crashes every time.
I just uninstalled version 16 and installed version 12 and now it's not crashing
