grumpybs
Aug 12, 2015Tutor
genie installer/updater not windows 10 compatable
I upgraded to Windows 10 and had netgear genie installed at the time. Genie worked just fine on Win 10 until I tried to upgrade to the newest version of genie. The installer deleted the old version a...
- Sep 02, 2015
Hi grumpybs,
The latest version of the NETGEAR Genie should be compatible with Windows 10. I suggest making sure that the program has been completely uninstalled by checking Programs and Features under Control Panel. You can then try to reinstall the program by downloading the latest version using he link below.
http://netgear.com/home/discover/apps/genie.aspx
Dexter
Community Team
bn0ran01
Oct 28, 2015Aspirant
I tried the recommed solusion for the same issue and it does not work on my Windows 10 Pro version. Any suggestions?
- tomdaltonzOct 28, 2015Star
Have you tried using the compatability troubleshooter on the program prior to installing it? I think I installed mine using Windows 7 settings.
- bn0ran01Oct 28, 2015Aspirant
tomdaltonz wrote:Have you tried using the compatability troubleshooter on the program prior to installing it? I think I installed mine using Windows 7 settings.
No I have not I will try it now thank you
