Ari_sydney
Mar 21, 2017Aspirant
Genie Login issue x6 r8000
Hi All, just wondering if anyone have similar issues..I'll be able to login to admin using browser but I'm unable to use genie app on both IOS and Android..I rebooted the router problem still per...
- Aug 24, 2017
Hi luterguy,
Please update the router to the latest firmware version (1.0.3.54) for the fix and do a factory reset. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
CraigX
Apr 01, 2017Aspirant
Hi,
Just found a bug in the latest Firmware from Netgear for the R8000 with regards to IOS Netgear Apps (including Genie). Roll back to Firmware V1.0.3.32_1.1.21 and the bug goes away. If you are using V1.0.3.32_1.1.25 (latest) you will have problems.
