Ari_sydney
Mar 21, 2017Aspirant
Genie Login issue x6 r8000
Hi All, just wondering if anyone have similar issues..I'll be able to login to admin using browser but I'm unable to use genie app on both IOS and Android..I rebooted the router problem still per...
- Aug 24, 2017
Hi luterguy,
Please update the router to the latest firmware version (1.0.3.54) for the fix and do a factory reset. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
kman68
May 15, 2017Star
Yes. It is also a problem for Android. Bought a new X6 last weekend. Worked great until it updated the firmware. Now I get that message in Genie.
- DexterJBMay 17, 2017NETGEAR Moderator
Hi all,
This has been reported to engineering and is being worked on. We will provide an update once available.
Dexter
Community Team
- HawtDogFlvrWtrJul 06, 2017Aspirant
This is still happening even with the latest firmware on 7/6/2017 even with V1.0.3.46_1.1.32 installed (latest). It would seem this isn't a prioritory fix. Especially when you purchase this router for the parental controls and the only way to set them is from the windows/mac/ios/android app, and none of them work.
