Rikds
Mar 19, 2024Aspirant
Genie Lost what now?
So much out there about the loss of Genie. I cannot find a solution despite reading masses of conversations. My PC (Windows 10) hard drive died and when the new one was installed I found that Genie h...
Rikds
Many thanks for your reply.
The router is installed and working fine. I used Genie to check my connection when the internet went down because we are on wireless link to the village server. It was very useful. I cannot find a system that does the job.
michaelkenward
Mar 20, 2024Guru - Experienced User
If you want to use the desktop Genie for Windows or Macs, it is still there, just well hidden:
Netgear is trying to kill this useful utility, but for the time being you can find it here:
genie | Product | Support | NETGEAR
Be warned that the genie installation file is wrapped up in a RAR archive that you have to decompress.
I use it all the time. Among other things, the Genie's network map is good for finding things on my network and then clicking through to them.
- RikdsMar 20, 2024Aspirant
Thanks for that but I'm pretty thick! What and where is an RAR file?
Cheers
- michaelkenwardMar 20, 2024Guru - Experienced User
The RAR file is behind the link I provided:
Click it.
Depending on which version you want, it takes you to:
There you can choose:
https://www.downloads.netgear.com/files/genie/NETGEAR_Genie-install_Windows_V2.4.64.rar
or
https://www.downloads.netgear.com/files/genie/NETGEAR_Genie_Installer_MAC_V2.4.45.rar
The rar file is really a sort of zip file. It unwraps to create an exe file.
Run that and it will install the genie.
New versions of Windows have a built-in rar unpacker. Otherwise, find a free one.
free rar extractor - Yahoo Search Results
Macs are unknown territory to me.
