Lomara
Nov 12, 2018Aspirant
Genie unable to login to WNDR4300 after firmware update V1.0.2.104
Hello,
I have recently updated my Netgear WNDR4300 to firmware V1.0.2.104 and now the Genie IOS app will not login. It fails with Login Failed. I am using the correct login/password combo that ...
- Mar 02, 2019
The Genie app is now able to login to my WNDR4300 again. I can see all of my network devices on it also.
The WNDR4300 is still on firmware V1.0.2.104
The Genie iOS app is now on 3.1.74
I can only assume it is due to an app update
I'll mark this thread solved.
schumaku
Nov 12, 2018Guru - Experienced User
Known interoperability issue -> https://community.netgear.com/t5/Genie/Genie-won-t-login-after-firmware-update/m-p/1655327#M9659
- LomaraNov 13, 2018AspirantThank you schumaku. I’ll watch that thread for updates.
