wflather's avatar
Feb 11, 2018
Genie won't connect to OpenDNS for Parental Controls
I get I know there is already a good thread on this subject, but this !@*&($@#*&#&  forum app WON'T let me add my question to that thread.  So we get a new thread, sorry.   I am using the PC versio...
  • wflather's avatar
    wflather
    Feb 21, 2018
    Solution found:
    Emailed support at: [email protected]
    They called while I was out of town, also emailed with a link to provide workable callback time and phone number as well as requested some basic system information.
    Tech called back right on time.
    Very polite and knowledgeable.
    Had me download and run a remote control app so he could directly manipulate my system.
    Updated firmware on router (even though router indicated firmware was up to date).
    Tech took the time to back up the router settings first.
    Re-downloaded latest Ver of Genie, which failed to work.
    We confirmed that I had the correct OpenDNS login/pw by directly accessing OpenDNS through their website.
    Uninstalled Genie, downloaded older version (2.4.38) from here: https://files.netgear-support.com/go/index.php?action=d&step=3
    Installed this version.
    This version of Genie connected successfully with Router and OpenDNS (after a couple tries, I probably entered password wrong)
    Genie is  now working correctly.
    Support this time was A+ in quality.
    Thanks!
